Thread: Sdk
  #23
Old 07-16-2012, 02:25 AM
dcnieho dcnieho is offline
Dear Farshizzo,
A full traceback is below. The thing is, i only get this error when i'm trying to throw an exception from my C++ plugin, otherwise all executes as it should. So that shouldn't be me using wrong syntax at the Python side, I think?
** Caught exception in main
  File "<string>", line 11, in <module>
  File "C:\dat\Vizard\walk_Dee_stimuli\script_walk.py", line 6, in <module>
    main.main()
  File "main.py", line 32, in main
    expt.startSesson()
  File "experiment.py", line 93, in startSesson
    self.stim.setStimSpec(cond.worldSpec)
  File "DNstimuli.py", line 62, in setStimSpec
    self.command(1,stimSpec)
  File "C:\Program Files (x86)\WorldViz\Vizard4\python\viz.py", line 7381, in command
    return _ipcSend(_VIZ_CMDEXTNODE,self.id,command,mesg,x,y,z,w)
TypeError: command must be an int
The self in DNstimuli refers to a class that derives from viz.VizExtensionNode. stimSpec there is a string (or however those are called in Pyhton).
Dee
