Thread: Timer issues
Old 07-04-2012, 10:17 PM
snovob93 snovob93 is offline
Timer issues
Below is the script we are using for the project. I wish to add a timer that starts as soon as the file is run and records the time and target number that was touched. It should keep doing this as each target is touched.
Hope someone can help!
import vizproximity
import viztask
import random
#Define session parameters
nTrial = 10;
nTargetList = [1,2,3,1,2,3,1,2,3,1];
#nRandList = random.shuffle(nTargetList)
print nTargetList
viz.setMultiSample(4)
viz.fov(60)
#Create Background and Main View
viz.clearcolor(viz.BLACK)
viz.MainView.setPosition(0,2,-6)
#Create Floor
floor = viz.add('ground.osgb')
#Connect to server at specified IP address
phasespace = viz.add('phasespace.dle',0,'10.3.6.119:2')
#Add first marker
marker1 = phasespace.addMarker(1)
#Target Marker (finger)
marker2 = phasespace.addMarker(5)
ball = viz.add('white_ball.wrl',color=viz.RED,cache=viz.C ACHE_CLONE)
viz.link(marker2,ball, priority=1)
#Create proximity manager
manager.setDebug(viz.ON)
#Spheres 1 : 4
spheres = []
sphereSensors = []
sphere1 = viz.add('ball.wrl')
sphere1.setPosition([0,0,0])
spheres.append(sphere1)
#proximity sensor-sphere
sphereSensor1 = vizproximity.Sensor(vizproximity.Box([0.5,0.5,0.5],center=[0,0.1,0]),source=sphere1)
#Add sensors to manager (sphere)
manager.addSensor(sphereSensor1)
sphereSensors.append(sphereSensor1)
sphere2 = viz.add('ball.wrl')
sphere2.setPosition([0,0.5,0])
spheres.append(sphere2)
sphereSensor2 = vizproximity.Sensor(vizproximity.Box([0.5,0.5,0.5],center=[0,0.1,0]),source=sphere2)
manager.addSensor(sphereSensor2)
sphereSensors.append(sphereSensor2)
sphere3 = viz.add('ball.wrl')
sphere3.setPosition([0,1,0])
spheres.append(sphere3)
sphereSensor3 = vizproximity.Sensor(vizproximity.Box([0.5,0.5,0.5],center=[0,0.1,0]),source=sphere3)
manager.addSensor(sphereSensor3)
sphereSensors.append(sphereSensor3)
sphere4 = viz.add('ball.wrl')
sphere4.setPosition([0,1.5,0])
spheres.append(sphere4)
sphereSensor4 = vizproximity.Sensor(vizproximity.Box([0.5,0.5,0.5],center=[0,0.1,0]),source=sphere4)
manager.addSensor(sphereSensor4)
sphereSensors.append(sphereSensor4)
#Add main viewpoint as proximity target
target = vizproximity.Target(marker2)
#Add viewpoint target to manager
manager.addTarget(target)
def destinationsTask():
fade1 = vizact.fadeTo(0,speed=2)
fade2 = vizact.fadeTo(1,speed=2)
spheres[1].addAction(fade1)
spheres[2].addAction(fade1)
spheres[3].addAction(fade1)
x = 1;
while x <= nTrial:
print 'Reach to start.'
yield viztask.waitTime(2)
yield vizproximity.waitEnter(sphereSensors[0])
spheres[0].addAction(fade1)
spheres[nTargetList[x]].addAction(fade2)
print 'Reach to target.'
yield viztask.waitTime(1)
yield vizproximity.waitEnter(sphereSensors[nTargetList[x]])
spheres[nTargetList[x]].addAction(fade1)
spheres[0].addAction(fade2)
x = x + 1;
print 'The end.'
viztask.schedule( destinationsTask() )
