Old 04-28-2005, 06:05 PM
Johannes Johannes is offline
Did a workaround by typing a lot of code (will improve it later with objects).
I tried it with vizard objects (toruses used for field lines), but I guess I have to do it with objects then I will be fine, so no need to answer this question if I have problems I will write again.
I moved small segments in the path of an ellipse. Unfortunately vizard only painted one side of the ellipse with color (red) the other side stayed dark. Could this be a problem with culling?
Johannes
