Old 04-30-2012, 08:49 AM
Is the model scaled properly? Sometimes it can seem the viewpoint is stuck but the model needs to be scaled down in size. You can check the model dimensions by loading it in Inspector.
Do you have the same problem if collision is disabled?
The Mainview is magically linked to the model. This has the effect, that none of the movements of the Mainview are visible on the screen, because the model just moves along.
How does the model move along?
