Old 04-08-2012, 07:48 PM
Darkmax Darkmax is offline
welcome to the forum.
Is because the viz.link, you need to make postTrans or preTrans or you can use these command <camera>.setGlobalMarker(marker) to make the marker the center of your virtual world and apply actions like you are doing instead of using the link, but with these you just can use one marker at the same time.
please use the code tags the next time when you want to show your code to maintain the spaces.
with setGlobalMarker
ar = viz.add('artoolkit.dle')
camera = ar.addWebCamera()
marker = camera.addMarker('ar/patt.worldviz',width=1000)
wheel = viz.add('wheelbarrow.ive')
camera.setGlobalMarker(marker)
moveForward = vizact.move(0,0,2,1)
moveBack = vizact.move(0,0,-2,1)
turnRight = vizact.spin(0,1,0,90,1)
turnLeft = vizact.spin(0,1,0,-90,1)
def mykeyboard(whichKey):
	if whichKey == viz.KEY_UP:
		wheel.addAction(moveForward)
	elif whichKey == viz.KEY_DOWN:
		wheel.addAction(moveBack)
	elif whichKey == viz.KEY_LEFT:
		wheel.addAction(turnLeft)
	elif whichKey == viz.KEY_RIGHT:
		wheel.addAction(turnRight)
viz.callback(viz.KEYDOWN_EVENT, mykeyboard)
