Old 03-28-2012, 10:08 PM
allanjjj allanjjj is offline
Unhappy Vizard AR Problem.....
i saw the code below is to display avatar only when the marker is shown, but when I run the script, the avatar still shows and jump randomly if no marker is shown in Camera. Is there any problem with the code below?
#Add ARToolkit extension
ar = viz.add('artoolkit.dle')
#Create camera using first available webcam
camera = ar.addWebCamera()
#Create matrix marker
marker = camera.addMatrixMarker(0,width=1000)
#Add avatar model and set state 1
avatar = viz.add('vcc_male.cfg')
avatar.state(1)
#Link avatar model to marker sensor
viz.link(marker,avatar)
#Method that update if the marker is visible
def updateVisible():
if marker.getVisible():
avatar.visible(viz.ON)
avatar.visible(viz.OFF)
vizact.ontimer(0,updateVisible)
