Thank you, the clearAttribute works fine.
I tried out some other things. And if I turn on lighting for the complete model, the <node>.color() command works, as you said.
The clearAttribute solves my problem, but in the model I exported there are also objects without textures. These object are rendered white (with lighting off). So the results are not as expected. I can fix those using clearAttribute.
I am not sure what the behaviour of the exporter should be. I never use VertexColors myself. But I think I would like a way to turn of the this white VertexColor generation, so that even with LIGHTING off the <node>.color() can be used.
