Old 02-15-2012, 03:26 PM
As I mentioned, the Cave object will automatically call <window>.frustum every frame if you specify a tracker. I noticed your code will call <window>.ortho under certain circumstances. So one call will be overriding the other, depending on which is called first. Do any of your code paths allow for <window>.ortho to be called while a tracker is specified for the cave object?
