Are you using the vizcave module? Depending on how you setup the Cave object, it will update the projection matrix every frame to account for the latest position of the head tracker. If you have other code running in a timer that tries to change the projection, then this could be the cause of the conflict. It's hard to say without seeing some sample code.
