Old 01-25-2012, 12:56 PM
Here is an example that shows one way of accomplishing this. I created a simple function LookAtBox that places the viewpoint at a specific distance and yaw from the box. I then use a task function to continually call the function for a 360 degree spin.
import vizshape
import viztask
box = vizshape.addBox(color=viz.GREEN,pos=(0,2,0))
vizshape.addGrid(color=[0.3]*3)
def LookAtBox(yaw,distance):
	pos = box.getPosition()
	viz.MainView.setPosition(pos)
	viz.MainView.setEuler([yaw,0,0])
	viz.MainView.move([0,0,-distance])
def SpinAroundBoxTask():
	# Create mix parameter for yaw (0-360) for 5 seconds
	yawAnimate = vizact.mix(0,360,time=5.0)
	# Animate viewpoint spinning around box at 8 meters away
	yield viztask.waitCall( LookAtBox , yawAnimate, 8.0 )
	print 'Finished spinning'
viztask.schedule( SpinAroundBoxTask() )
