Old 01-18-2012, 01:37 PM
There should be other developers and support team members active on this forum.
Your sample code never actually calls the removeInfoImage command. I tried adding a call to that command and it seems to work fine. You will need to make sure it is called after showInfoImage since the infoQuad attribute will not have been created yet.
