Old 12-20-2011, 10:29 AM
Hi alvinadi,
Though the tutorial shows a model that has been split up into multiple parts, this is not a requirement of exporting. You can use as few or as many different parts as you want in the model.
If you did need to export the model in parts, the most straightforward way to do it would be to:
-detach any parts you want separated from an unskinned model
-select all the parts
-add a Skin modifier
A second way to do it with an already skinned model involves selection sets, and cloning.
