Old 12-20-2011, 04:34 AM
madeinjava madeinjava is offline
Smile Solved! :)
Originally Posted by madeinjava View Post
Hi all,
I need to make some keyboard shortcut (instead a single button) into my VR world. Its work fine when only using single button shortcut like this:
def onKeyDown(key):
if key == 'c':
print 'Hello World!'
However I want to assign a standard windows shortcut, like: Ctrl+z, Ctrl+v, or maybe just 2 or 3 button combinations ('a'+'b' button, etc.)etc.
How I can implement this? I tried using:
if key == viz.key.allDown(['a','b']):
I tried using anyDown() as well but none of this works.
Any suggestion what should I do? or I made a mistake there?
Thanks alot!
Problem solved!
Basically I need to 'listen' first from keypress (using onKeyDown) and then checks every keyhits on allDown or anyDown function.
Ps. thanks to clevr team for give me the hint
