Are you exporting the model from max? If so, it looks like you didn't export the model with a texture applied to the label. If you don't export with a texture applied, then there will not be any texture coordinates assigned to the sub-mesh. This is why the texture does not appear when you apply it within Vizard. Try assigning some placeholder texture to the label within max and reexport it.
