Old 12-07-2011, 09:55 AM
First off, I would avoid using getChild unless you need to modify the transform of the child. If you just need to change the texture, then use the optional node parameter of the texture command:
model.texture(labelMat,node='Label-GEODE')
Are you getting any error messages? Can you send us the model?
