Old 12-05-2011, 08:37 PM
There's documentation for the wiimote plug-in the Vizard Help. Also if you search for wiimote in these forums you'll find some example code. You can use vizact.onupdate or vizact.ontimer to register a callback function that gets called every frame. Within your function you can update the hand position based on wiimote data.
