Hey,
I'm using Vizard 3, and when using the 3d screem to check the stage, or when using the program in debug mode, where the input isn't from the PPT, everything is ok - the eye height is correct and so's the movement speed.
I've now recalibrated the PPT, and set evey value under "tune" to 1, but the problem of movement speed & wrong eye height persist when not scaled, and when scaled by the quoted factors, there's still view-point skipping.
Also, I recreated an empty set, with just the stage and no programming code whatsoever, and the same problems persisted.
