Overlaying Textures with Alpha Masks
Hey,
I need to overlay one or more textures with alpha masks on top of an object's original texture within Vizard. Will multitexturing work for this? What blend settings should I use? Ideally, the alpha masks on the additional textures would dictate how the textures are blended...
I'm also having problems with texturing faces. I looked at a previous post that suggested using the following code in order to make the texture coordinates work:
newtexture = viz.add(texture)
newtexture.wrap(viz.WRAP_S,viz.REPEAT)
newtexture.wrap(viz.WRAP_T,viz.REPEAT)
This works when applying the texture to the default layer (textureNum 0) with the following code for example:
self.head.texture(newtexture, 'geom_0')
But it doesn't seem to work correctly for code like this (regardless of how I blend the textures afterwards):
self.head.texture(newtexture, 'geom_0', 1)
Any suggestions?
Thanks!
-Josh
