Old 12-01-2011, 05:48 PM
You can use the viz.grab command to grab objects:
import viztracker
viz.setMultiSample(4)
viz.fov(60)
viz.addChild('ground.osgb')
viz.clearcolor(viz.GRAY)
#Add the object that will do the grabbing
hand = viz.addChild('marker.wrl')
#link the hand to a 3D mousetracker
mouseTracker = viztracker.MouseTracker()
mouseTracker.scroll(-8)
viz.link(mouseTracker,hand)
#turn off mouse navigation and hide cursor
viz.mouse(viz.OFF)
viz.mouse.setVisible(viz.OFF)
#Add the object that the marker will grab
ball = viz.addChild( 'basketball.osgb',pos=[0.5,1.8,2.5],scale=[2,2,2])
link = None #The handle to the link object
def grabBall():
	global link
	link = viz.grab( hand, ball )
def releaseBall():
	global link
	link.remove()
	link = None
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,grabBall)
vizact.onmouseup(viz.MOUSEBUTTON_LEFT,releaseBall)
If you want a hand model that's animated when it grabs take a look at Grabbing with viztracker. That requires a configuration file that you create using the viztrackersetup utility. Make sure have Keybd w/ Mouse Hands set for tracker type, as shown in the image.
