Vizard-PPT conversion
Hi, three questions which are basically the same:
a. is there a way to adjust the movement speed inside the vizard simulation, when the input is from a ppt-tracker? if so, how?
b. same for adjusting eye-height.
c. Is there a way to convert from the point-system in the ppt to the scene in the vizard, and vice-versa?
Basically, I'm replacing the former VR lab programmer which more or less disappeared, and there's a problem with the simulation he left, that the movement speed is very slow. I tried scaling the scene down, but this seemed to have just scaled the POV and movement speed of the PPT with it, as far as I can see - movement is very slow.
