Hi
Sorry maybe i didnt explain the problem well enough.
I have created i scene where you walk around and click on objects. When you click on an object you then pivot navigate around that object.
It works fine most of the time but occasionally if the person is walking down a slope(which i cant remove) and clicks on an object the pivot camera has the gravity still appied to it.
The best way to consitantly recreate the problem is to click on an object whilst falling.
To simplfy the problem in the example code i have removed the clicking on the object with a button and i dont position the pivot navigate camera. The gravity still is applied to the camera.
