Thread: Cluster
Old 11-06-2011, 12:04 AM
inha inha is offline
Cluster
I use one main-computer and three cluster computers.
Three screens are connected with the three computers.
UpperLeftWindow = viz.addWindow(pos=(0,1.0),size=(0.2,0.4))
UpperLeftWindow.visible(0,viz.SCREEN)
BirdView = viz.addView()
#Attach the bird's eye view to the upper left window
UpperLeftWindow.setView(BirdView)
#Move the view above the center of the room
BirdView.setPosition([40,-9550,0])
#Rotate the view so that it looks down
BirdView.setEuler([0,90,0])
I added a small window using this code.
I had not any problem when I used only one computer. However, the small window on the left of the top of this attached picture appeared on each screen of the three computers while I used them.
I would like to make the window appear on only one screen.
I suppose that I can solve the problem using SETMASK code but I failed to settle the problem although I tried many times.
I would appreciate it if you can help me.
