Old 03-23-2005, 11:09 AM
Johannes Johannes is offline
Thank you, that fixes my confusion about the printouts!
The problem thought still persists and should not exist following the printout, I will explain it:
The position of the redOpaque gets transferred to an array (inside a director function):
000j2 [[-0.20000000000000001, 0.84999999999999998, -0.59523463611544603]]
in a timer-function I printout the array:
ggg [[-0.20000000000000001, 0.84999999999999998, -0.59523463611544603]]
So the position is in it.
When the BallSubClass is called a new object get's created. Which is working as I see
Loading File: ../resources/joNew/050305_ballRedOpac.WRL
It is also accessing the superClass to initialize Values (Speed =2):
slfvy 2.0
The position is still in the array before it get's deleted.
I wonder why I see the loading file but don't see the ball in my scene? This error is happening seldom, usually it works but sometimes it does not work. I was not able to find a pattern yet.
Johannes
