Each machine in the cluster will need an Enterprise license, otherwise your cluster will run in trial mode, which limits the duration of your simulation to 4 minutes.
Do you have two separate machines rendering the top/bottom portions, or is the same machine rendering them? One machine can render multiple walls of a cave. If your client is rendering both the top and bottom portion of the wall, then you need just a single Enterprise license for that machine.
Let me know if anything is unclear or you have anymore questions.
