Old 10-25-2011, 11:52 AM
theuberk theuberk is offline
Wiifit Balance Board
I'm trying to connect a wiifit balance board to Vizard, but can't seem to get it to work. I'm assuming the wiimote plugin does not support the balance board as it is not documented. I can connect to the wiifit using the wiimote plugin and change the LED states on the board, but I don't know how to gather data from it. Is there any simple hackery I could use to get the data somehow, or will I have to write a custom plugin?
I've tried all of the options in the wiimote driver to see if the sensor data was translated to wiimote position/button press data, but everything returned zero or was empty.
