Old 10-25-2011, 11:24 AM
vasiliys vasiliys is offline
Originally Posted by Jeff View Post
Try using a task function to control the program flow....
Thanks Jeff, I figured it out yesterday and made a solution similar to yours (though your method looks neater than mine so I will use it instead).
So from what I understand, though the clearcolor function was executing Vizard was only noting what color to change to. The color would actually change only once control flow was returned to Vizard - which is why it would appear as if only the final color was used.
Thanks for your help!
