Flock of Birds
I've got a problem with the flock of birds (ascension) 6dof tracker. When it's connected to my laptop by a com-to-USB converter the drivers assign a 10+ com port number. With this high com-port number Vizard failes to connect to the FOB while winbird (test program) connects just fine. Test with a different laptop that assigned lower com-port numbers succeeded.
Is it correct that the problem is that the high com-port number are not allowed in the Vizard fob drivers? and how can i solve this all lower com-port numbers are currently reserved or in use.
