don't think so, but here is the code (purpose is to get access to the menue while being in VR):
def mouseclick(button):
	global beginPos0502, line0503,counterMaterialSelectMenue,info,i, counterGraphSelectMenue,infoArray0513
	pos = viz.mousepos()
	#print 'mouse is currently at',pos
		if info.materialSelectLock==1:
			#print 'counterMaterialSelectMenue:',counterMaterialSelectMenue
			counterMaterialSelectMenue=counterMaterialSelectMenue%6
			if (counterMaterialSelectMenue==0):
				radioPine.set(True)
			if (counterMaterialSelectMenue==1):
				radioPlastic.set(True)
			if (counterMaterialSelectMenue==2):
				radioGranite.set(True)
			if (counterMaterialSelectMenue==3):
				radioBronze.set(True)
			if (counterMaterialSelectMenue==4):
				radioSilver.set(True)
			if (counterMaterialSelectMenue==5):
				radioGold.set(True)
			counterMaterialSelectMenue=counterMaterialSelectMenue+1
		if infoUIWorld.graphSelectLock==1:
			infoArray0513=infoUIWorldArray
			#print 'counterGraphSelectMenue:',counterGraphSelectMenue
			counterGraphSelectMenue=counterGraphSelectMenue%13
			setMenueSelectionZero(infoUIWorldArray)
			selectUnselectMenueItem(infoUIWorldArray[counterGraphSelectMenue])
			counterGraphSelectMenue=counterGraphSelectMenue+1
 the mouseclick function goes on but as it is declared global in the first line of mouseclick it normally should be fine.  Guess I will have to live with the "warning"
