Thank you.
It works 90 % fine.
When the user klicks on the graphOnWall Checkbox again, before the projection-surface is completely up, the graphs get put in the air.
I guess that is because while the projection-Surface is moved up and the user clicks the checkbox the movement is stopped => ACTION_END_EVENT is triggered, checkbox is ON and so the graphs get put in the air.
To solve this I would need to check, if the ACTION_END_EVENT occured after the surface moved down vs. up.
Sorry, solved it while writing this:
if checkboxWall.get()==1 and screenWall.get(viz.POSITION)[1]==0:
