Old 08-26-2011, 12:45 AM
sleiN13 sleiN13 is offline
your code seems correct. language vizard uses is python you can work with that like c#
define classes will make things clearer most of the time.
class something(object):
also you could use if a == 'a' and b == 'b':
and elif instead of
if:
I replaced your door opening code with a print
print "print this string"
and I got the correct results so maybe check if your tabs are placed correctly for all the if statements.
