Old 06-28-2011, 10:37 AM
The intersense plugin uses the official isense SDK to communicate with the devices. There doesn't appear to be any way to change the transmission mode between continuous and polled through the SDK. It appears the SDK defaults to polled for older serial-based devices.
I know the SDK supports specifying extra options through an INI config file. Maybe there is a special option for changing to continuous mode. You will need to contact Intersense about this though.
