Old 06-28-2011, 09:24 AM
kevin kevin is offline
I was wrong about the SX setup function showing better results; running it again caused the same problem as the SX/111. There are no high poly objects in the scene; only a plane and a few cylinders.
We've realized that the problem may have something to do with the Intersense tracker. When we first start the tracking system, ISDemo shows a data transfer rate of about 85 kbps. As soon as Vizard connects using the intersense.dls plug-in, however, that data transfer rate drops to 16 kbps, and remains there unless we turn the Intersense system off and on again.
The Intersense version were using is an older IS-900 which connects via a serial port.
