Old 03-07-2005, 10:08 AM
JRichizzle JRichizzle is offline
I've installed the opensource module for communicating through the serial port. Connected to the serial port, I have a numeric keypad. For any number I press, when I issue a command to read the port (e.g., "port.read()") a series of the following kind of data are shown:
\x80
Data encoded like this are called a "two's complement little-endian binary string"
By using the Python module "pickle," this data can be decoded into the following:
-128L
...which itself is encoded and is called a "long."
Have you ever dealt with this kind of encoded data? ...and decoding of said data? If not, can you refer me to a helpful resource ?
