Old 06-23-2011, 11:36 AM
Does it also turn with the camera, or just move? If it's only moving, then it sounds like the scale of the model is very large. In this case try scaling it down. You can also try adding the following line of code before adding the model:
viz.setOption('viz.model.apply_collada_scale',1)
viz.add('file.dae')
This will automatically scale the collada model to meters if the model units are specified within the dae file.
