Thread: Emagin Z800
Old 06-23-2011, 03:08 AM
sleiN13 sleiN13 is offline
Emagin Z800
The Emagin Z800 headtracking doesn't work in Vizard 4, it produces the following error message in vizard:
emagin.dls eMagin v2.0
** ERROR: Could not connect to eMagin device. Error: 80004005
When I run the same code on the same machine with Vizard 3 it works fine. I've tested it by switching back and forth between the two versions with the same results everytime.
PS.
Is there a section where you can report bugs for Vizard 4?
