Thread: preEuler help?
Old 06-14-2011, 11:19 AM
Kaminski Kaminski is offline
preEuler help?
Hey all,
preEuler doesn't seem to work how I understand it to. I want to wear the HMD at a certain orientation, measure the Euler, and then apply the opposite of the Euler values as a preEuler. Would that not then make the orientation [0,0,0]?
the code that I am using is like this:
isense = viz.add('intersense.dle')
tr = isense.addTracker()
main = viz.link(tr,viz.MainView)
def mainLoop():
    viztask.waitKeyDown(' ')
    ori = main.getEuler()
    main.preEuler([-1*ori[0],-1*ori[1],-1*ori[2]],2,viz.LINK_ORI_OP)
    print main.getEuler()
When I run this, however, the printed orientations will vary from 0 to 3 degrees. I don't believe it is drift from the intersense because if I run the program multiple times with the HMD stationary I always get the same output.
Am I doing this right?
