Old 06-07-2011, 03:08 AM
Saz Saz is offline
Hi Jeff,
thanks for that; yes, that's the idea but it's a follow on from another experiment so it has to have an identical set up as before, ie the surface and position of the road, the temporal frequency of the lines, plus the road needs to continue indefinitely to the end of the experiment.
All the other parts are already coded (although I may need to call upon your expertise for additional parts of the experiment - sorry!) so it's just really a case of assigning a left quad to the left window and right quad to the right window using the code that I already have.
Is this possible or do I need to change the code so that it is similar to what you have written?
