Old 05-31-2011, 05:58 PM
Vizard is not able to connect to either the Polhemus or Emagin sensors.
Polhemus - Test with the following script:
polhemus = viz.add('polhemus.dle')
patriot = polhemus.addPatriot()
viz.link(patriot,viz.MainView)
If you get errors verify that you can connect to the Polhemus device in PiMgr. When running Vizard, PiMgr should be closed.
Emagin - Try the following:
emagin = viz.add('emagin.dls')
viz.link(emagin,viz.MainView)
Do you get errors? Have you installed the USB drivers for the Emagin sensor?
