Thread: Sdk
Old 05-23-2011, 10:09 PM
dcnieho dcnieho is offline
Hi Farshizzo,
Thank you for all the detailed information! I still have some questions though:
Originally Posted by farshizzo View Post
No, but you can internally save a reference to them. This is what most of the built-in plugins do. For example, the extension class can keep a list of sensor objects created by it:
std::list< viz::ref_ptr< MySensor > > m_sensors;
Is this supposed to be
std::list< osg::ref_ptr< MySensor > > m_sensors;
instead? I don't seem to have a viz::ref_ptr (but do have a viz::Referenced*). In any case, things seem to work fine with osg::ref_ptr
The new interface allows you to return arbitrary Python objects from the command method, so you can return anything you wish to signal an error. If you want to raise a Python exception from your plugin, then you can use the Python PyErr_SetString function to raise an exception.
I am trying the Python PyErr_SetString method and I'm having some trouble with it. If I do a normal (non-debug) run and raise/set an error in my plugin, an error occurs on the next command call in the python node class that interfaces with the C++ node instance:
  File "<string>", line 11, in <module>
  File "C:\dat\C\projects\Vizard dll\testCustomNode.py", line 58, in <module>
    stim.setStimSpec('GDcl')
  File "DNstimuli.py", line 45, in setStimSpec
    self.command(1,stimSpec)
  File "C:\Program Files\WorldViz\Vizard4\python\viz.py", line 6837, in command
    return _ipcSend(_VIZ_CMDEXTNODE,self.id,command,mesg,x,y,z,w)
TypeError: command must be an int
The line self.command(1,stimSpec) is the first command I sent to the node after the command in which the exception was raised (which created no output or anything when raised), there can be any amount of code in between these two calls.
If setup a debug breakpoint on this first call after the raised exception (self.command(1,stimSpec)), and try to step into it, i get this output:
C:\Program Files\WorldViz\Vizard4\python\vizbdb.py:410: RuntimeWarning: tp_compare didn't return -1 or -2 for exception
  if id in ids:
  File "C:\Program Files\WorldViz\Vizard4\python\vizbdb.py", line 254, in trace_debug
    self.wait_for_input(frame,None)
  File "C:\Program Files\WorldViz\Vizard4\python\vizbdb.py", line 436, in wait_for_input
    id,data = self.wait_for_message(_INPUT_MESSAGES)
  File "C:\Program Files\WorldViz\Vizard4\python\vizbdb.py", line 410, in wait_for_message
    if id in ids:
RuntimeError: testing
The good part here is that "RuntimeError: testing" is what I am throwing from the C++ code (PyErr_SetString(PyExc_RuntimeError, "testing");)
Other things I tried:
- doing data.set( PYTHON_RETURN_OBJECT, PYTHON_INT(-1)); or data.set(PYTHON_RETURN_OBJECT, NULL); after the call to PyErr_SetString did not help (inspired by some reading of how error states should be communicated from Python).
- try/except around the call where the exception is raised. This didn't do anything, as expected when the exception goes unnoticed.
What am I missing? Thanks for your help!
