Old 05-20-2011, 12:30 PM
Make sure you have full administrator rights on that machine. Being logged in as admin is not always enough. You must also launch Vizard with "Run as admin" method and then run the target script using the parallel port. "Run as admin" done once should be enough and not then required on subsequent executions.
Running as admin should not be necessary for Vizard 4
