Old 05-16-2011, 03:31 PM
Are you using the S3TC Texture compression? If it’s set to IMAGE_DATE_FORMAT, the size will be bigger, but it wont have any compression. S3TC_ DXT5_COMPRESSION compresses and maintains the texture quality best.
What are the UV coordinates like? Maybe not enough room is allocated to receive textures. If that’s the case, it might also serve to break up the object to receive more texture sheets.
