I connected one output of the Matrox TripleHead2Go (which was feed to the xSight HMD) to a normal LCD monitor and the weird texture was seen on the LCD monitor as well. This clearly suggest that the problem I got is not caused by the Sensics HMD or the Sensics Vizard plug-in. It is apparently caused by the Matrox TripleHead2Go.
Since we used the same Matrox device with Virtools previously and it worked fine. I feel that the problem might due to the incompatibility between Matrox and Vizard. Or it might be a bug in the Vizard 4 beta2. I have not tested it with other version of the Vizard yet.
