			Thank you for the reply.Indeed this system is using an Ati Rage chip 32 mb.  I'm using the latest trial edition, which i download this morning.
 Is this glitch on all Ati chips or only on the older rage boards?
 By the way this happens with al
 examples which are included with the trial.
 is there a work-around?
 Because we might use this system
 to develop, but the final system which
 will run the VR simulation, will use a
 Nvidia Quadro FX 3400, that shouldn't
 be a problem right?
 I sure hope there is a workaround.
 Is the same function used for text to create a 2D visual interface in the VR-app with your software?
 thanks in advance,
 greets,
 Kevin
