Thread: User-Interface
Old 02-15-2005, 11:35 AM
Johannes Johannes is offline
Originally posted by farshizzo
2) Tooltips are not built-in, but it should be possible. Perhaps you could use the vizinfo library.
Don't understand this. What did you think here?
I originally wanted to use the tooltipps for objects in the world (if you move with the mouse above them, a tooltip popps up and shows some of the properties of the objects)...
I know that originally tooltipps are used for menues etc. in the user interface... Maybe that's because you wrote vizinfo...
But other than in the help I don't find docu to the vizinfo class. So what were you referencing to when you mentiond 'use the vizinfo library'?
All the other questions are resloved, thank's for your answer.
Johannes
