Old 02-15-2011, 09:58 AM
1) Have you tried disabling lighting just on the node?
node.disable(viz.LIGHTING)
I just tested this out with the custom node example, and I don't get any dimming.
2) There is no automatic velocity computation for nodes, unless you are using physics. You will need to save the previous values and compute the velocities yourself.
