Old 02-13-2011, 10:45 PM
dcnieho dcnieho is offline
CustomNode wrapping in python
Hi all,
(I'm using the Vizard 4.0 beta)
I'm trying to write a wrapper around a customnode plugin I created following the example in the SDK.
I'm new to Python however, and this is proving difficult.
I have the wrapper in a separate module, "DNstimuli.py" (this pretty much follows code for a sensor wrapper that I found on the forum):
class DNStimuli(viz.VizCustomChild):
	def testCall(self):
		self.command(1, 'TX')
viz.upgradeCustomNode('customnode',DNStimuli)
def addDNStimuli():
	return viz.add('customnode.dlc')
I then use it as follows:
from DNstimuli import addDNStimuli
custom = addDNStimuli()
custom.testCall()
This errors with:
  File "<string>", line 11, in <module>
  File "C:\dat\C\projects\Vizard dll\quicktest.py", line 7, in <module>
    custom.testCall()
AttributeError: 'VizCustomChild' object has no attribute 'testCall'
What am I doing wrong / how do I do this cleanly? I want to keep my syntax simple and short in the main script, from what I think I've learned about Python, I therefore need to import the specific components from the module or I'll have to prefix everything by the module name.
Thank you for the advice and help in getting me started with this part of the job!
Best,
Dee
