Old 02-04-2011, 06:21 PM
You should use the vizjoy.add command only once. The data from both joysticks will be accessible from that joy object. Depending on the device you are using this information will be encoded in different ways. So, to get the positional information from the second joystick you might have to look at the hat or slider data. Try running joystick.py in the examples->input folder of the Vizard installation to see where that data is showing up.
