Old 02-04-2011, 02:19 PM
EnvisMJ EnvisMJ is offline
2nd Analog Stick on Gamepad
We're using a Logitech Wirless Gamepad F710, the default code allows me to access all 12 button inputs and the left analog stick. (Sweet!)
But I'm trying to get input from the second analog stick, and I keep getting "WARNING: Failed to connect to joystick" in the console when I try to add the second one using the code below:
import vizjoy
#Add a joystick. This will return the first detected joystick
joy = vizjoy.add()
joy2 = vizjoy.add()
#Initialize global joystick position variable
joyPOS = [.00001,.00001]
#Record the position of the joystick in for use in onTimer function
def joyMove( e ):
    global joyPOS
    #Save position in global
    joyPOS = e.pos
#If the joystick position changed, call joyMove
viz.callback( vizjoy.MOVE_EVENT, joyMove )
Any suggestions?
