PPT-Intersense post-calibration tuning
I received help from WorldViz support in calibrating a PPT-Intersense 6DOF setup in November. The setup functions, but in our small space PPT seems to lose track of the marker (a headset) near the edges of the room, catapulting the user across the virtual space in a seemingly random direction. Will tuning fix this, or is there something else I can do to get PPT to hold onto the marker a little better?
I have an additional question relating to Vizard, but I understand if I need to ask that in the appropriate forum. I need to scale the user's movement speed up a bit to maneuver through the larger virtual space in our limited physical space. I have been using
"headlink.postScale([15,1,15])"
to accomplish this, but it seems to have an upper limit preventing me from scaling up movement to a desired level, no matter what numbers I put in. Am I doing something wrong, or is there a better function I can use?
Thank you,
Billy
