Old 01-13-2011, 05:51 AM
Zword Zword is offline
moving object forward backward
When the mouse is pointed at the object I want to move it depending on wich key i press. A normal int number works but example +=0.5 does not work.
cube = vizshape.addCube()
def moveForward():
	object = viz.pick()
	if object.valid():
		pos += 10
		object.setPosition([pos],0,0)
		print 'move backward'
vizact.onkeydown( 'w', moveForward )
def moveBackward ():
	object = viz.pick()
	if object.valid():
		pos += 10
	print 'move forward'
vizact.onkeydown( 's', moveBackward )
